aof85
Apr 01, 2018Follower
Magenta light on RBS50 - Instability increasing
After about 4 months of realtive stability, my RBS50 continues to lose connectivity from the RBR50 located ony 30' away through wood framing. I will reset it, it will be BLUE for a while, and then turn MAGENTA at random intervals. It is becoming untenable, and highly irritating - defeating the entire purpose of this expensive system. Is there a definitive sequence for resetting or perhaps troubleshooting this? I have reset, performed a sync with both units next to each other. It doesn't improve the continued drop out of the RBS50. Any known defects or failures of the RBS50s? The RBR50 seems to work fine. Thank you.
I would try the Beta FW thats now availalbe for your model:
Please do a factory reset on both Router and Satellite after installing the FW file. Upgrade the Satellite first then the router.
- Retired_Member
when is this "Beta FW " going to be ready for prime time?
Don't know. it maybe still in flux and in development so there maybe a new version seen upon official realease.
Beta is working well for me. 40ft distance between my router and 1 satellite. 3 wooden walls inbetween.
- st_shawMaster
Try moving the router and/or satellite so they are closer and/or have fewer obstructions between them.
