iNeusch
Jan 11, 2020Aspirant
Magenta status in the app ?
Hi all ! Just got my orbi system setup Seems to work ok except I hard a very hard time to connect the satellites... I ended un getting an Ethernet cable and connected via backhaul Could never get ...
- Jan 12, 2020Ok huge progress here !
Realized having a netgear managed switch between all devices was the problem
Connected the Ethernet cables directly between the orbi router and satellites and it now works... all satellites appear blue and connected via cables (wired)
Trick was to do initial setup with all three in the same room, then wait for it to settle down
Then connect Ethernet cables (still in same room) directly on router, wait for it to settle down
Then once all reporting wired connection move the satellites to target position
Keyword : patience !
Jan 11, 2020Guru - Experienced User
What Firmware is currently loaded on RBS and RBR. Should be same version of FW on both.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
iNeusch
Thanks a lot, some answers and results of my tests later on
- What Firmware is currently loaded on RBS and RBR ? V2.5.1.8 On all
- What is the Mfr and model# of the ISP modem the NG router is connected too? What ? :D Im' in Europe, Fiblre modem from Orange
- What is the size of your home? Sq Ft? Something like 2000 sq ft
- What is the distance between the router and satellite(s)? I am in the 20 ft average distance
- What channels are you using? Auto? OK will try this
- Any Wifi Neighbors near by? If so, how many? Yup, 5 or 6
- Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. OK will try this
- Try disabling the following : Armor, Circle. Not in router mode so not available
- Try disabling the following : Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. OK will try this
- iNeuschJan 12, 2020AspirantOk huge progress here !
