iNeusch's avatar
iNeusch
Magenta status in the app ?
Hi all ! Just got my orbi system setup Seems to work ok except I hard a very hard time to connect the satellites... I ended un getting an Ethernet cable and connected via backhaul Could never get ...
  • iNeusch's avatar
    iNeusch
    Jan 12, 2020
    Ok huge progress here !
    Realized having a netgear managed switch between all devices was the problem
    Connected the Ethernet cables directly between the orbi router and satellites and it now works... all satellites appear blue and connected via cables (wired)
    Trick was to do initial setup with all three in the same room, then wait for it to settle down
    Then connect Ethernet cables (still in same room) directly on router, wait for it to settle down
    Then once all reporting wired connection move the satellites to target position
    Keyword : patience !
