dorindon
Jun 14, 2017Guide
major security problem: new Orbi RBK50 router + wireless : SSID does not ask for login or password
Hello, Just bought new Orbi RBK50 router + extender. Login to orbilogin.net, system configuration no problem (which I am used to) Setup SSID login and pass as well as Orbi login and pass. Hit the...
- Jun 14, 2017
Every time you connect to a new AP from one iOS or Mac device the password is stored in iCloud Keychain. This means ALL your iOS/Apple devices will connect automatically without entering a password, just as you described.
To prove this to yourself, do the following on your iOS device. Settings, Wi-Fi, click the little i in the cicle next to your Orbi. Now click "Forget this Network"
Now, try to connect again. Your device will ask for the password this time.
tomsliwowski
Jun 14, 2017Apprentice
Maybe I'm not quite understanding your issue but...what are you talking about?
For normal operation you just need the SSID and the password (hopefully WPA2-PSK) unless you disabled encryption. Once a client is connected it's free to access all the resources including going to the internet. The client won't have access to your router admin page without providing a username and password.
If you want to set up access controls you would do that in Advanced -> Security -> Access Control.
- dorindonJun 14, 2017Guide
Hello and thaks for taking time to consider my question.
You said: For normal operation you just need the SSID and the password (WPA2-PSK): yes, that it what I did, and I therefore expect any new device to ask for a password the first time I pick the Orbi SSID.
Just so there is no misunderstanding I am very familiar with computers (MAC), routers, etc. Just to let you know, my level is (usually) quite advanced.
The problem is the following: i went through the complete installation procedure as I have done many time in the past.
I also checked all the parameters: encryption on, NO guests allowed, etc
I obviously configured the router so that the SSID requires a password (with letters and numbers for security purposes) and rechecked the configuration multiple times before posting in this forum.
- I take my iPhone, ➤ settings ➤ WiFi ➤ tap on the SSID ... and I log in AUTOMATICALLY without entering the password. I tested the browser and yes, I have full speed Internet via WiFi (not 4G). I am sure that it is the WiFi, if only the fact that it is much faster than 4G.
-As a second step, I take my iPad which does not even have a SIM (WiFi access only). I go to settings, WiFi, click on the SSID (Orbi857) and presto I have full access again without entering a password.
I checked the configuration, reset the router, updated the firmware, etc which did not solve the problem
thanks again
dorindon
- rhester72Jun 14, 2017Virtuoso
If you replaced an old wifi setup that had the same SSID and password as the Orbi, your devices have it cached, which is why you aren't being prompted - clients can't tell what hardware they are talking to, only the (B)SSID.
I do strongly recommend WPA2-PSK only, as TKIP was broken some time ago.
Rodney
Hello,
The SSID and password are completely different.
thanks for your input,
dorindon
- st_shawJun 14, 2017Master
Once you enter an SSID/password combination on one of your IOS devices, it is shared with all your other IOS devices. It's working just as designed as has nothing to do with Orbi. If you don't like that behavior, you can probably disable it via iCloud or something.
Thank you for your answer.
You make an interesting point.
1- In other words, is the SSID and password are different from that of my old router, you are confident that all the people in my building are not going to login to my SSID without a password?
I read that Netgear had some security issues. Can I be confident that this is not a security issue, or some configuration glitch that makes my wifi public (given that I clearly defined a password) ?
2- do you selectively allow devices or is that overkill?
thanks again very much
