dorindon's avatar
Jun 14, 2017
major security problem: new Orbi RBK50 router + wireless : SSID does not ask for login or password
Hello, Just bought new Orbi RBK50 router + extender. Login to orbilogin.net, system configuration no problem (which I am used to) Setup SSID login and pass as well as Orbi login and pass. Hit the...
  • st_shaw's avatar
    st_shaw
    Jun 14, 2017
    Every time you connect to a new AP from one iOS or Mac device the password is stored in iCloud Keychain.  This means ALL your iOS/Apple devices will connect automatically without entering a password, just as you described.
    To prove this to yourself, do the following on your iOS device.  Settings, Wi-Fi, click the little i in the cicle next to your Orbi.  Now click "Forget this Network"
    Now, try to connect again.  Your device will ask for the password this time.
