Mooose
Jan 30, 2019Luminary
Massive packet loss over Ethernet backhaul
I believe I have read all the threads on this topic and tried the suggested solutions that are relevant to my particular network. My apologies if I have missed something!
My Orbi RBK50 (one rou...
- Feb 06, 2019
Mooose Good troubleshooting and interesting observations. It's clear that the packet loss is directly related to the wired backhaul.
I'm now running the ongoing beta software (2.3.0.23) and I can see that NG has done quite good improvements on wired device handling. Would you want to test this SW and see if you will see improvements? If yes, please PM to ChristineT and ask to get the SW download links.
CrimpOn
Jan 30, 2019Guru - Experienced User
It was in the first post with the diagrams. First thing he did was change from the original ethernet cable to a brand new short one. He also removed the switch. This is a VERY strange situation.
Mooose
Annoying how the family typically has little understanding for the need to fix something that appears to "mostly work". (Until the movie they're trying to watch stops, of course!)
The 10.#.#.# range is by choice, I use it both because it is faster to type, and I can also easily see if a device is on my network or some other network, which typically uses 192.168.#.#.
I do have some concern regarding the Ethernet cable run through the house, but for the test I moved the satellite near the router and used a short (>3m) ridiculously overpriced Cat 6 cable, which I hope is fine. I do have one more of those to try though, so I will do that.
Please note also that the switch (a D-Link DGS-1005D 5-port unmanaged 1000 Mbps) was never between the router and satellite. In the normal setup (first diagram) it is connected to a LAN port of the router since the devices connected to it (Drobo 5N, Ikea Tradfri gateway and a Raspberry Pi) are far enough away from the router that I do not want to use separate cables. I also connect other devices from time to time, and there are not enough ports on the router to do that.
For the second test (third and fourth diagrams) I added the switch to a LAN port of the satellite to determine if having it (and the Drobo) also connected would cause any issues. As noted, no packet loss with 5G, but only adding the backhaul Ethernet cable directly between the router and satellite immediately resulted in packet loss.
Please also note that for the first test (second diagram) the switch was entirely removed from the equation, no other wired devices than the router, satellite, fiber-optic to Ethernet converter and the two laptops were connected. However, several other devices were connected through wifi, which I could not turn off without causing a major disruption for others.
Thanks everyone for your input!
- MoooseJan 31, 2019Luminary
What I intend to do:
- Download RBR50-V2.2.1.210.img and RBS50-V2.2.1.210.img from the Netgear support page
- Use the web interface in the current setup to update first the satellite and then the router
- Disconnect all Ethernet cables from router and satellite
- Reset router and satellite using paperclip in reset button for more than seven seconds
- Power off router and satellite
- Power on router
- Connect a laptop to router through wifi
- Set IP range to 10.1.1.* (in order to force new addresses for all devices as they are connected)
- Reserve 10.1.1.101 for wifi connected laptop
- Power on satellite, wait for 5G backhaul to be established
- Reserve 10.1.1.2 for satellite
- Connect laptop (with wifi off) to LAN port of satellite
- Reserve 10.1.1.102 for wired laptop
- Run ping test from laptop connected to router through wifi (10.1.1.101) to laptop wired (10.1.1.102) to satellite, confirm no packet loss
- Connect short Cat 6 backhaul cable and confirm good wired connection in web interface
- Run the same ping test again
- Replace the wired laptop with a different wired laptop, reserve 10.1.1.103 and test again
I will do this with the WAN port disconnected, and with the default wifi network, so none of my other wifi devices (Ring Doorbell, Piper Z-wave gateway, phones, tablets, etc) connect.
Are they any steps I should add? Anything I should do differently?
- FURRYe38Jan 31, 2019Guru - Experienced User
I would skip powering off the router and satellite after doing a reset. Theres no need to do this. Just continue to setup the router from scratch.
Though changing IP addresses shouldn't be a problem, you could ping test this using default IP address first to see if there is any differences. Then go back to your custome address pool.
I would first test pings with the satellite not being added first. Then wireless connect the satellite. Ping test. Then connect the ethernet to the satellite. GIVE 5 Minutes for the system to settle in. Then ping test at the router then behind the satellite.
- Power on router
- MoooseFeb 05, 2019Luminary
(Sorry about the multiple reposts, it seems the forum deletes my post when I attempt to add images.)
I basically tried the approach above, with the exception that the updated and reset virgin Orbi's startup wizard process wanted the satellite connected and laptop connected through wifi before proceeding.
Once the network was up in its default configuration I wired one laptop with wifi disabled to the router and one to the satellite.
After each of the following steps I performed a long and successful ping test:
- Wire the Drobo to the satellite
- Add a short high quality Cat 6 between the router and satellite, and wait for the backhaul connection to stabilize
- Add the DGS-1005D switch between the satellite and the Drobo
- Add additional wired devices to the switch
- Move the satellite to the remote location and wait for the 5G backhaul connection to stabilize
- Wire the Nintendo Switch and the Apple TV to LAN ports of the satellite
- Wire the DGS-1005D with the Drobo and Ikea Gateway to the router
- Connect the WAN port to the fiber-optic converter
- Connect the long backhaul Ethernet cable and wait for the connection to stabilize
- Connect a third computer to the network through wifi
Every time I added a wired device I reserved the IP address, and when I added the wifi devices I reserved all their addresses as well.
At this point I let the ping test run all day, with almost perfect results, and I was about ready to proclaim myself a believer in voodoo.
Here is a typical run:
I changed the default wifi SSID to what it was previously allowing other devices already configured to rejoin.
Failure!
I realize now that what I failed to do in the very basic setup I tried first was to disable (or rename) the Orbi wifi, and that my wifi devices were still connected during the test.
I have tried loads and loads of things during the last week, including creating a guest network with the old SSID and password where the wifi devices could not see each other or the rest of the network, none of which produced different results.
My conclusions are that:
- If my wifi devices and the Ethernet backhaul are connected there is significant packet loss (typically about 15% but up to 80% in some tests)
- If I disconnect the Ethernet backhaul and wait for the 5G backhaul to establish the packet loss goes away
- If I rename the wifi so that all wifi devices are kicked off the network the packet loss goes away
- When there is packet loss, it typically happens to devices that are at the other end of the Ethernet backhaul, others are fine
- Keeping an eye on the ping stream the chunks of packet loss to different devices seem fairly synchronized i.e. 192.168.1.5 and 192.168.1.10 will drop pings at the same time
The reasonable thing to do would be to configure a new wifi network and add devices back one at a time. However, I've already lost a week of productivity to this and I do not have more time to spend. The devices include five wifi speakers, four Ring devices, two Z-wave gateways, three headless computers and a printer which all would require the wifi swapping configuration dance.
I guess my options now are to live with the high latency or throw the Orbi out and try something else, neither are good options.
I really don't want to live with the latency as it is so much higher than it needs to be for the wired devices.
Here's one of the tests with the Ethernet backhaul conducted on a wired computer:
And the same test with 5G backhaul:
The average ping for devices on the other end of the backhaul is typically about 0.3 ms versus 3.3 ms with 5G backhaul, which is really depressing.
(In the examples above 192.168.1.1 and 192.168.1.5 are wired devices at the other end of the backhaul and 192.168.1.3 and 192.168.1.8 are wired devices connected at the same end. The rest are wifi connected to either router or satellite.)
