BretD
Jan 03, 2018Administrator
Meet Orbi Outdoor - Better WiFi. Indoors and Out
Editors Note: Stay tuned, our CES 2018 Coverage is just getting started!
Now stay connected both in and around the home from the backyard to the front porch with the Orbi Outdoor – Orbi Model R...
lowepg
Jan 04, 2018Apprentice
Also, re-reading the specs (as I said- I really would like to like this- becuase I need it).
2500 sq feet coverage? Outdoors?
So that's, what, 28' or 30' range?
That might be OK indoors- but thats really NOT very much for an outdoor application.
I wonder if they just "winged-it" with those specs?
for comparison, the $150 ubiquity has arange of about 500'!
BretD
Jan 05, 2018Administrator
Thank you for all the feedback so far.
If you look at the disclaimer on the Orbi boxes, the Sq feet number refers to WiFi Connection speeds of <100mbs. You will definitely still get a WiFi signal outside of the 2500sq feet range but usually at a reduced bandwidth.
- turnerm05Jan 05, 2018Luminary
Maybe the 2500 SF range is somehow factoring in the average uptime after multiple random reboots per day? LOL!
- AnonymousJan 06, 2018
I bought a 3rd satellite and ran it 40 feet into the woods from my house. I bought a waterproof electrical junction box and ran 14/2 UF wire to it. UF can be buried without conduit. I plug it into an outdoor plug on the side of the house. I used a spade and made a 12" slit in the ground to bury the wire. Spray painted the box brown to match the pine needles. My ring cameras out from the house had 4 green bars during wifi pairing. I tested it first with an extension cord to make sure it would work before I bought a 3rd satellite and utility box.
- cue003Jan 06, 2018ApprenticeRetired_Member... any pics of the finished weatherproof box and electrical setup? Thx
