Jaystill29's avatar
Jaystill29
Follower
May 27, 2021
Mesh wifi
Is the nighthawk Triband WiFi 6 ax3600 better than the orbi rbk752
  • Yes nighthawk is better than orbi rbk752 because orbi rbk752 will bound you for some limits where in nighthawk you can give you more free hand to yourself.
  • plemans's avatar
    Are you talking of comparing the MK83 system to the RBK752 system?
    the MK83 uses at 1800mbps backhaul with a 1200/600mbps front haul
    the RBK752 uses a 2400mbps backhaul with a 1200/600mbps front haul
    both have the same ethernet ports.
    RBK752 is based on the orbi firmware
    MK83 is open mesh based.
    Basically it comes down to what you prefer.
