spalatin1020's avatar
spalatin1020
Initiate
Apr 14, 2020
Mix Orbi Satelites
I want to add another satelites but the same models are pricey in and of themselves. I noticed that there was a model out there that was on special and wondered if I can mix these two together. Orbi Voice AC2200 Tri-Band Wi-Fi Range Extender and Smart Speaker. I was wondering if I were to be able to mix then what models could I mix it with. Thank you for your help with this.
  • plemans's avatar
    yes you can mix the extenders between the orbi router. and the RBR50 has the best backhaul so all the AC satellites should work.
    RBS20
    RBW30
    RBS30
    RBS40
    RBS40V
    RBS50Y
    • spalatin1020's avatar
      spalatin1020
      Initiate
      You are a godsend. I was looking for a while on Google with no luck. Thanks again!
      • plemans's avatar
        sorry extenders=satellites.
