jmschnur923
Nov 28, 2017Luminary
Mixed 50 router and rbs 50 rbs 40 sats firmware
I am awating an ew orbi system which is mixed (frm Amazon). It will be the RBK 50 kit plus an RBS 40 Sat. How do I best update an RBR 50 router and two different sat (RBS 40 and RBS 50). Are the...
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
You will want to have all units on the latest firmware you could see issues if the routers and satellites are on different firmware.
DarrenM
- jmschnur923Nov 29, 2017Luminary
Since this a new install , how do I check and then update firmware as I proceed?
Can I setup with the existing firmware and then update the rbs50 and rbs40 first and then the router manually or will this happen automatically on the install.
if then what?
joel
The rbs40 and rbs 50 have different firmware. 2.074, and 2.056. Does that matter ? Or is the “latest” ok?
- aani75Nov 29, 2017Apprentice
I was successfully able to sync up RBR50 with RBS50 and RBS40. I purchased 2 kits (RBK50 and RBK43). This is how I did it.
1- Setup RBR50 router
2- RBS50 was already synced out of the box with RBR50
3- I reset first RBS40 by pressing reset button and restart it, wait for atleast 2-3 minutes after start.
4- Then clicked on Sync button on RBR50, causing blinking white
5- Then clicked on Sync button on RBS40, in few minutes I got solid blue on RBS40.
Repeat Step 3-5 for other RBS40 satellites.
This results in a spare RBR40. Waiting for Netgear to allow routers to act as satellite so I can add RBR40 as a satellite using same procedure. Hope that helps.
