walkerx's avatar
walkerx
Guide
Mar 05, 2019
Mixed satellite connection
If I use the Orbi satellites in a mixed mode configuration so one is wired and the other is wireless, do you need to enable the daisy chain backhaul or should it be left disabled?   I'm still run...
