Nozzer
Aug 11, 2019Aspirant
Mixed wired / wireless and daisy chained back haul?
This closed thread states you can login into a device in your setup directly and configure that one device to be daisy chained even though other nodes are wired/wireless back haul. I've tried logging...
Aug 11, 2019Guru - Experienced User
Anything regarding configuration of the RBS or RBR is done thru the RBRs web page. Daisy Chain is found under Advanced Tab/Advanced Settings/Wireless Settings. It's recommended to disable Daisy Chain while having a RBS connected in ethernet mode.
You can log into the RBS web page using there IP address however only FW update and checking status features are seen here. Nothing else.
Nozzer wrote:This closed thread states you can login into a device in your setup directly and configure that one device to be daisy chained even though other nodes are wired/wireless back haul. I've tried logging in (successfully) and can see no options to configure the node "locally". I'm running the latest software ( not beta ).
How do I find the local settings if they're not in the admin menu on the local device? Thanks!
https://community.netgear.com/t5/Orbi/Daisy-chain-ethernet-backhaul/td-p/1696894
