dklimas
Feb 21, 2019Apprentice
Mixture of star and daisy chain topology
My house is in the shape of a very large L and where the network switch, cable, and router for the whole house is in the corner of the L in the master bedroom closet. I currently have the router plac...
- Feb 21, 20191. If all Satellites use wireless backhaul and you want to allow Satellites to also connect to other Satellites and not only to the Router the Daisy Chain should be enabled (checked) so Satellites will have the choice to connect to the node that has better coverage whether its a Router or Satellite.
2. If all Satellites are wired then the Daisy Chain setting is not relevant.
3. If you will have a mix of wired and wireless Satellites then the Daisy Chain option is only valid to which topology you want the wireless Satellites to take.
In the current software (2.2.1.210) there is a sw bug that in some cases causes issues when you have wired backhaul and you enable Daisy Chain, but it seems to be solved in the ongoing beta.
ekhalil
Feb 22, 2019Master
franktribe wrote:
Do you know if the current and/or the beta firmware allows for 2 satelittes connected to the router via Ethernet (Ethernet backhaul) actually works? In prior versions of the firmware I couldn't have both satelittles connected via Ethernet. So, I went back to 5GHz wireless backhaul. That is very stable. But, the Ethernet backhaul used to be unstable. But, I haven't tried it in a while. Curious if it is better with the .210 firmware or the beta.
Many Ethernet backhaul issues were solved in 2.2.1.210 but that also introduced some LAN port handling issues. It seems that majority of -if not all- these issues are resolved in the ongoing beta software.
franktribe
Feb 22, 2019Apprentice
Great to hear!!!! Thank you.
