cjc182's avatar
cjc182
Modem to accompany my Orbi RBR50
Hi, I have an ORBI RBR 50 with an ORBI satellite.
I use a rented Xfinity modem but would like to replace it with with my own modem.
The Xfinity modem is an ARRIS T25 cable modem with voice.
Can someone suggest a modem that would work well with my Orbi set-up?
Thanks.
  • Retired_Member's avatar
    Retired_Member
    I would check with your internet provider
  • SB8200 is approved by Comcast and I've been using it with my RBR50.  Check out the review comments on Amazon.
  • FURRYe38's avatar
    IF you need phone support with the modem, you can review NetGears CM1150v modem. Has phone support if you need this feature. Make sure the ISP you have supports it.
    Thanks.
    • cjc182's avatar
      cjc182
      Thanks for the recommendations, especially on the Comcast-approved SB8200.
      II will look into it.
