parout
Jun 03, 2018Aspirant
Moving; do i need to do a reset?
I am moving. I will be transferring my same internet service. The question is do I need to reset my system when I move to my new place or merely plug and play? Thanks
parout
Thanks, Furry! I am keeping the same ISP and modem so I should be fine on plug and play. Didn't know if changing the promixity of the two devices would change anything. I suspect my satellite will be a bit closer then I have them now.
Jun 04, 2018Guru - Experienced User
No, you should be fine.
Enjoy.
