Pittro's avatar
Pittro
moving my orbi to different location
I want to take my orbi system to work...few questions...1 the modem / router combo at work is a cradelpoint ..do i put my orbi router in AP mode for it to work & 2 do i use my password to connect...
  • FURRYe38's avatar
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
    • Pittro's avatar
      Pittro
      If I use so mode...when you say turn off all Wi-Fi radios do you mean unplug the modem / router CradlePoint
    • Pittro's avatar
      Pittro
      Well ...i just plugged orbi router into cradelpoint modem & then connected the Satelitte and it worked great...beautiful streaming all night long...no buffering...Thanks The Orbi is Great !!!
