Orbi-wan_Kinobi
Jun 18, 2020Initiate
Multiple 2.5.1 Firmware Updates?
Hello, i have a question regarding the 2.5.1 firmware update. I have an Orbi router with 3 Orbit satellites and the Orbi app indicated that an update needed to be done. But the update runs multiple...
- Jun 18, 2020
Best way to ensure FW is updated correctly is to manually download the FW files:
Update the RBS first then RBR lastly. You can apply FW updates on the RBS web page.
Orbi-wan_Kinobi
Thanks Furrye38!!! I accessed my router through my Mac's browser instead of my iPad (using the app) and i was able to get to the manual update. And as you indicated, running the update from there fixed the problem. All my devices are at the 2.5.1 now. Thanks for all your help! Much appreciated!
Jun 18, 2020Guru - Experienced User
Enjoy. :smileywink:
