mscofield
Aug 16, 2017Aspirant
Multiple Orbi routers
Is it possible to purchase a second Orbi router and run it in AP mode to further extend the reach in a large house.
When attempting to connect a second satilte in basement no connection. I do have CAT 5 run to the basement, hence my question about a second router.
- st_shawMaster
If possible, it would be better to move the router to a central location in the house that allowed connection to all satellite locations. If you have wires in place, can you move the router to a better location? You didn't say what type of service you have, but if you have cable or DSL the router could be on a different floor than the modem.
- mscofieldAspirant
I am talking 5000 sq feet on each level. the basement has a CAT5 connection available, but when i moved the second satellite down to the basement no go. As an alternative can the satellite be plug into the CAT5 thru to the router?
- st_shawMaster
You cannot wire the satellite. There's a chance this will be added in a future firmware release.
You could tray a second Orbi in the basement, but it's unknown whether the backhaul signals from two Orbis will coexist without interference.
