LewB
Aug 08, 2017Aspirant
Multiple SSID's on RBK50
I have the RBK50 system with one satellite. After setting it up and getting the latest firmware I find three SSID's for it: SSID, SSID2 and SSID3. I also have a guest network and it is set up as an A...
DarrenM
Aug 10, 2017Sr. NETGEAR Moderator
Hello LewB
There should be one main network and one for the guest network what names are the others showing up as? do they have the same name as your main SSID?
DarrenM
- LewBAug 10, 2017Aspirant
I have my SSID (not publishing it) same SSID2, same SSID3, and guest SSID, plus your usual assortment of neighbors. The computer is a 2 year old dual band Dell. My older, 2,4g computer, in the basement just shows the one SSID and the guest SSID.
- DarrenMAug 10, 2017Sr. NETGEAR Moderator
Hello LewB
Sounds like a strange issue with the wireless drivers in that PC I would try to find the latest ones for that pc.DarrenM
