Sven62
Nov 01, 2016Tutor
Multiple wifi radios
Hello! Just hooked up and updated my Orbi. I am adding Orbi to an existing WiFi cable modem/router (Motorola SB6580). Should I... 1) Rename Orbi network to existing network? 2) Run two s...
loomis1975
Nov 01, 2016Luminary
Turn off WiFi radio on cable/modem router and let the Orbi handle all the wireless. Run the Orbi in AP mode and let your modem router handle the DHCP and such. Although you probably already did that (put Orbi into AP mode).
Sven62
Nov 01, 2016Tutor
Excellent that is my current setup. Thanks!
