Erwin1981
Apr 19, 2019Aspirant
multiroom audio is not working properly (speaker model: Libratone)
Hi - I have the orbi RBK40 and purchased it (as many of you have) to be able to have full throughput in my apartment to enjoy multiroom audio - a year back I purchased Libratone ZIPP speakers and have now 5 distributed in all rooms. For some reasons however, it doesn't always work very smooth and customer support told me to enable b/g/n which I have.
Also the suggestion is to run the speakers only on 2.4 GhZ or with one router - does anybody had the same experiences and has some ideas?
One idea would be to run them on a guest network but that way, we most likely can't access them via Airplay but have to always choose spotify connect, right?
Thanks !
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Thanks !
Thanks !
- Erwin1981Aspirant
Hi - thanks for the very detailled response - sorry it took me some time to actually sit down and look at it properly. So here are all the answers :-)
I have switched recently to Airplay2 for audio streaming and it is working slightly better - but now there is a delay between the different speakers - so still not a perfect solution. Will try out your recommendations and see if it makes things better.
Thanks again,
Armin
PS - see my settings below
2.3.1.48 (just loaded)What is the Mfr and model# of the ISP modem the NG router is connected too?
Connected to FritzBox 6490 Cable (WLAN disabled) - NG Router is the Orbi RBR40
90 sqm = 968,752 SqFt (very thick concrete walls)
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Distance is 10 m = 32 feet - there are 2 walls in between them but also 2 open doors
Yes using Auto on 2.4 Ghz - switched to channel
5 GhZ is on Channel 36
Yes, there are many 6-7 Wifi (2 of those are public hotspots)What WPA security modes are you using?
WPA2-PSK (AES)Try enabling Beamforming and MIMO and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
BEAMFORMING, MU-MIMO enabledWMM was alreday enabled
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s)Daisy Chain still enabled
Fast Roaming disabled
20/40 Mhz enabled
IPv6 did not find it
Ok let us know how it goes.
Thanks again,
Armin
