andy_HK's avatar
andy_HK
My AC2200 connection to satellite became POOR
I just buy the AC2200 for just one month.   Everything is fine until today, the connection between main and satellite sudden dropped from 5G to 2.4G and the connection from satellite to device dropped from 240Mbps to 20-30Mbps.   I had tried to turn off and turn on the machine for both, but cannot help and recover, any suggestion?
  • FURRYe38's avatar
    What FW is currently loaded?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
    If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
    https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
