SeaMonkey80
Jul 13, 2018Apprentice
My Ethernet Backhaul Setup
Sorry in advance for the long post.
I have been following this forum as an observer for quite a while now, and have noticed that many people are having issues with their Orbi setup, either when...
Aug 14, 2018Guru - Experienced User
ed-m
Aug 15, 2018Aspirant
I'm attempting to use an RBR50 with 2 RBS50 satelites with a wired backhaul. I agree with one of the posters above about the setup being "metastable". Some times it works, sometimes it doesn't. If I power cycle after a problem, it seems that any wired connection to the RBR50 works, but wifi to either the RBR or RBS units fails to connect.
I'm pretty disappointed as this was an expensive setup, and my initial elation at having a strong wifi signal throughout the house has faded away. I'm wasting hours of time rebooting routers, and trying to get everything running which lasts for a day or two, then I'm running around the house plugging and unplugging devices hoping that one of the power cycles will fix it.
BTW, running 2.1.4.16 firmware
- SeaMonkey80Aug 15, 2018Apprentice
ed-m, when you power cycle the Orbi system, are you keeping the satellites plugged in via the ethernet cables to the RBR50? If so, then this is probably why it is not connecting properly to your wireless clients. Whenever you do the reset dance, you should unplug the ethernet cables linking the orbis together, and have it connect to the wireless backhaul first. Then, once the satellite is connected and synced with the RBR50, plug in the ethernet cable and it should switch over to wired backhaul.
- striolaAug 15, 2018Guide
I just installed Google Wifi in my parents' house since Orbi has been too unreliable for me. Pros and cons to each system, but in my limited experience the ease of setup and reliability of Google wifi clearly wins out based on current firmware. Hopefully Netgear can make much needed improvements.
As a side note, one of my Arlo cameras has stopped functioning properly after the latest firmware update. I don't know what is going on over at Netgear QA, but it's not good. I'm regretting investing in their systems given all of the bugs they are pushing out.
- ed-mAug 16, 2018Aspirant
SeaMonkey80 , thanks for the reply. I hadn't tried that, and that is possible for one of the satelites to establish a wifi backhaul first, but for the second one, the signal is just not strong enough for the wifi backhaul to connect. But I think your idea is good, and in fact yesterday I finally got the second satelite to work by deleting it, bringing it next to the RBR, and syncing the units over wifi, then I moved the satelite back and connected it with ethernet and all seems good for now .....
... but....
I shouldn't have to jump through hoops everytime there is a hiccup..... the firmware needs to improve..... and I'm not sure what happens for the rest of the family if i'm not around the next time there's a problem.
Thank you for jumping in and responding to my post yesterday ..... I appreciate the help :)
- FURRYe38Aug 16, 2018Guru - Experienced User
You guys might hope over to the new beta test thread and see about getting some new beta to try. Migtht be worth testing it out and see if this helps this...
... but....
- michel1918Feb 17, 2019Tutor
Ouch.
This is not the kind of story I was looking for. I am thinking about buying the Orbi RBK50 with 2 sattelites, and with the price of 495 I would expect things to work nice.
Esepcially with everything wired together I assumed the only real thing the Orbi has to do is to 'mesh'.
I now have an Engenius Access point which works ok but doesn't cover the entire house 100%, and I really thought with spending 500 euro's, I could stay away from the hell of "I'm wasting hours of time rebooting routers, and trying to get everything running which lasts for a day or two, then I'm running around the house plugging and unplugging devices hoping that one of the power cycles will fix it."
I've just tried a Devolo WiFi powerline system (300 euro's) but this also gave me the '90%' of the time experience, and the other 10% it was resetting and replugging devices.
