SeaMonkey80
Jul 13, 2018Apprentice
My Ethernet Backhaul Setup
Sorry in advance for the long post.
I have been following this forum as an observer for quite a while now, and have noticed that many people are having issues with their Orbi setup, either when...
michel1918
Feb 17, 2019Tutor
Thanks very much for your clear schema.
What I noticed is that everything is 'behind' the Orbi router. Is that necessary?
Do you know if it also works if for instance the 'TL-SG108' switch would have been between the 'XFinity XB6' and the Orbi router?
The reason I ask is this: I had the setup that I had a cable directly from the modem into the Orbi router. When I plugged in my TV-settop-box in the Orbi, I had hickups in the TV stream. So it surprised me a bit that you managed to get it working with 'all your internet devices' behind the Orbi router.
- ekhalilFeb 18, 2019Master
........If you connect the switch to the ISP router then you can't connect the satellites to (unless you want Orbi to be in AP Mode).
michel1918 wrote:
The reason I ask is this: I had the setup that I had a cable directly from the modem into the Orbi router. When I plugged in my TV-settop-box in the Orbi, I had hickups in the TV stream. So it surprised me a bit that you managed to get it working with 'all your internet devices' behind the Orbi router.What is the type of the TV settop-box that you have? Does it do any IGMP multicasting?
- michel1918Feb 18, 2019Tutor
Yes, I do want it to work like an AP, so that woudln't be a problem.
The settop box I'll have to check, the ' Does it do any IGMP multicasting' is not in my vocubalary :-)
You can read about multicast here: https://kb.netgear.com/000037833/What-are-multicast-and-IGMP-snooping-and-how-do-I-configure-them-on-my-GS808E-S8000-Nighthawk-Switch
- FURRYe38Feb 19, 2019Guru - Experienced User
Orbi doesn't like managed or green ethernet switches.
Your model switch seems to support green tech and some IGMP protocols seen on managed switches:
- Green Ethernet technology saves power consumption
- IEEE 802.3x flow control provides reliable data transfer
- Steel housing, desktop or wall-mounting design
- Support 802.1p/DSCP QoS and IGMP Snooping function
If you can disable these features, the switch may work with Orbi, if not, I recommend trying a switch that is not managed, or has any green ethernet features. NG's GS105/108 series should be reviewed.
