SeaMonkey80
Jul 13, 2018Apprentice
My Ethernet Backhaul Setup
Sorry in advance for the long post.
I have been following this forum as an observer for quite a while now, and have noticed that many people are having issues with their Orbi setup, either when...
michel1918
Feb 17, 2019Tutor
Thanks very much for your clear schema.
What I noticed is that everything is 'behind' the Orbi router. Is that necessary?
Do you know if it also works if for instance the 'TL-SG108' switch would have been between the 'XFinity XB6' and the Orbi router?
The reason I ask is this: I had the setup that I had a cable directly from the modem into the Orbi router. When I plugged in my TV-settop-box in the Orbi, I had hickups in the TV stream. So it surprised me a bit that you managed to get it working with 'all your internet devices' behind the Orbi router.
ekhalil
Feb 18, 2019Master
If you connect the switch to the ISP router then you can't connect the satellites to (unless you want Orbi to be in AP Mode).
What is the type of the TV settop-box that you have? Does it do any IGMP multicasting?
- michel1918Feb 18, 2019Tutor
Yes, I do want it to work like an AP, so that woudln't be a problem.
The settop box I'll have to check, the ' Does it do any IGMP multicasting' is not in my vocubalary :-)
- ekhalilFeb 18, 2019Master
You can read about multicast here: https://kb.netgear.com/000037833/What-are-multicast-and-IGMP-snooping-and-how-do-I-configure-them-on-my-GS808E-S8000-Nighthawk-Switch
