Peace_105
Apr 30, 2018Aspirant
My only ONE (1) satellite repeatedly disconnects after AUTO-update of firmware v. 2.1.4.10
Symptom: As title says - the one (1) and only Orbi Satellite goes on cycles: connected , disconnected from the Orbi Router within a few minutes (ie goes Magenta --> Blue --> Magenta --> Blue etc). It...
Apr 30, 2018Guru - Experienced User
You can try reverting FW versions to last working version as well.
Maybe disconnect the satelllite while your away and then work on it after you come back...
- Peace_105Apr 30, 2018Aspirant
I just did a factory reset of both Orbi satellite and Orbi Router, as family members were upset and wanted wi-fi in whole house....and the Orbi piece of garbage auto-updated to v2.1.4.10 without even asking (apparently directly after factory reset),
So same problem, Satellite disconnects - Moment 22 -
I'm not not sure I understand how to 1) revert back to an earlier FW version? and then 2) to prevent the Orbi from auto-update?
