Peace_105
Apr 30, 2018Aspirant
My only ONE (1) satellite repeatedly disconnects after AUTO-update of firmware v. 2.1.4.10
Symptom: As title says - the one (1) and only Orbi Satellite goes on cycles: connected , disconnected from the Orbi Router within a few minutes (ie goes Magenta --> Blue --> Magenta --> Blue etc). It...
Apr 30, 2018Guru - Experienced User
You can try reverting FW versions to last working version as well.
Maybe disconnect the satelllite while your away and then work on it after you come back...
Peace_105
I just did a factory reset of both Orbi satellite and Orbi Router, as family members were upset and wanted wi-fi in whole house....and the Orbi piece of garbage auto-updated to v2.1.4.10 without even asking (apparently directly after factory reset),
So same problem, Satellite disconnects - Moment 22 -
I'm not not sure I understand how to 1) revert back to an earlier FW version? and then 2) to prevent the Orbi from auto-update?
