thebrecks
Oct 16, 2022Aspirant
My RBS50 satellite has no ring light
My satellite RBS50 has no ring light at all. Power is on and attempted reset a few times. Does this mean the satellite is bad? The base router is working fine. I guess I can buy a new one if that is the case. Could there possibly be an issue with the main router or is it likely just a dead satellite? Ethernet from the main router out to where the satellite is works fine if I plug directly into a computer
So powering OFF the RBS for 10 seconds then back ON doesn't produce a WHITE blinking light at all after it's turned on?
Is there a red or green LED in back?
