russthau
Aug 22, 2021Aspirant
My RBS50 satellites experiencing high latency and packet loss
I have gigabit fiber coming into my house and have been using an RBR50 with two RBS50 satellites through the pandemic. With the latest firmware release I noticed that my network speeds are great. 100s down and up. The problem is packet loss and latency which is terrible for Zoom and online games like Fortnite. I rolled back the firmware to 2.7.2.104 and found the problem to be with my RBS50 satellites. Getting a connection off the RBR50 is great.
I unplugged and plugged in everything. No change. I then reset both Satellites and it worked fine for a day and now back to crap. I can't figure out if the Satellites have just died and it is time to get new ones. Or, if something is wrong.
What's strange is everything worked great before the firmware upgrade.
Any experts have thoughts on what to do to get my mesh network working great again?
Has a factory reset and setup from scratch been performed since last FW update on the RBR?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.Any Wifi Neighbors near by? If so, how many?
- russthauAspirant
I didn't do a reset to scratch. Just the power cycle after the firmware upgrade numerous times. What doesn't make sense is that my current set up worked perfectly for a year and a half. I did a firmware upgrade that caused issues and rolled it back. I think this might be the issue, but I don't know.
What I am trying to determine is how the set up stops working. Could it be hardware failure? The firmware? A new neighbor device? I live in San Francisco so there are WiFi access points all over the place.
I'd start by turning OFF RBS 1 at a time.
Then try 1 RBS online one at a time.
Swap RBS locations to see if problem follows.
