dingzheng
Aug 03, 2018Tutor
Nas and orbi
I used to use tp link ac2800, for half year, it has alot of issues such as it has two wifi names i had to change between 2.4 and 5 g my self, and the 5g always jammed, and so on, however, i never had problem with my synology nas.
Got this orbi about 2 weeks, coverage is good, i use dm200 as modem, the speed is slower thann before (50 down to 41), i believe it was due to dm 200 rather than this orbi, so draytek vigor 130 is on its way, hopefully it will help.
I place one upstairs and the main router downstairs, the probelm is now.
1. it looks i have some kind of stream problem, my tv is next to router wifi connected, never has any issue of stream from my nas, however, the upstairs one does. While i can stream 4k movies (50gb) from downstairs, it will leg even when i stream hd size (4g ish).
2. Also, it seems, not sure yet, from upstair to downstair, my laptop changed network so, while it can accesses my nas from upstair i wont be able to access from downstairs until i reboot the laptop, and vice verse .
Is there anyone has the similar issues and how did you solve it, do you think it is due to the latest update, as i read someone mentioned about the legging issue with update.
If the issue resist i am think to go back to modem router rather than mesh.
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Used kasperskey as fw and if you were asking about the fw on router, i did not change anything at all.
The house is not big, and the strainght distance between two of them is definitely less than 10 foot, and the single given was good.
Did not think i need to set up so many other things, but, thanks
What FW version is currently loaded on the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials. If anything closer, thats too close.Please give the other suggestions a try.
