Betocamara
Apr 02, 2018Aspirant
NAS and RBK53 best Connection to Router or Satellite
I have a RBK53, is it possible to configure one satellite wired and the second wireless expanding the first wired satellite signal instead of using the router? Do I have a performance loss in ...
Apr 02, 2018Guru - Experienced User
Performances should be the same if wired backhaul.
Might see if Daisy Chain feature works.
The more you put something in the middle of a wired connection, there can be some degradation. Best to keep things simple as possible. If you need performances with NAS then you might consider a external Gb switch after the router and connect the NAS and any wired PCs and devices to this switch. Be sure its a NON-Managed switch. Don't use a managed switch.
