BigDingus's avatar
Apr 22, 2022
NAT Stopping FTP
Hi folks.
I've been trying to use FTP downloads to my PC but can't get the data connection to work.
It was working fine when I had a DGND3700 but when I changed to Orbi the problems started.
Through working with guys on help forums, it seems the Orbi stops the data connections NAT style.
Does anyone know how I can bypass any restriction?
I've added the ports to the forwarding section already.
  • Just an update.
    After managing to borrow another router I found it wasn’t the NAT that was causing the problem.
    I did however find it was due to some bad coding in my server.
    Thanks for the help
  • FURRYe38's avatar
    What orbi model system do you have?
    • BigDingus's avatar
      BigDingus
      Tutor
      Thanks for the quick response.
      It's an RBR50 with V2.7.4.24
      There's no model number on the modem but it's supplied by Virgin Media.
      However it's the same one that worked ok with my last router.
      • FURRYe38's avatar
        Would need more information on the Virgin Media modem. Most of these have a built in router which could cause problems. Need the model # to verify this...
