mickoe's avatar
mickoe
Follower
Oct 18, 2022
NBK752 no Firmware support at all?
Hi,
I am just wondering if there's any firmware update or support for this system at all from Netgear or if it's a lost system. The stability of the system is "ok", but not above average. In contrast to the RBS750 where I can see continuous support for firmware and security updates, there's nothing for the NBK752 series. The one and only firmware that's available is the "initial" release from last year. So any ideas when there's a newer firmware for the Orbi NBK ...?
Michael
1 Reply
  • plemans's avatar
    They don't tell us when firmware releases are or whats being worked on.
    But you will see releases take longer with those devices that aren't just routers. The modem/router combo devices (or lte devices) do have extra coding/work on them so take longer.
