sethm1's avatar
sethm1
Guide
Jun 29, 2020
Need another ethernet port
Rbk50.
This one only has 3 ethernet ports - I need a fourth.
I preordered the Wyze outdoor camera which comes with its own wifi base station.
would I be able to use a splitter such as this....
https://www.amazon.com/Network-Ethernet-Splitter-Suitable-Connector/dp/B085ZSD6K6/ref=sr_1_2?crid=F0Z26K95LID0&dchild=1&keywords=ethernet+port+splitter+1+male+2+female&qid=1593494994&sprefix=ethernet+port+s%2Caps%2C217&sr=8-2
thx.
  • Wouldn't be overkill, switches are inexpensive and easy to setup. Turn ON and plug in play. Your up and running. You can plug any wired device into the RBS.
    sethm1 wrote:
    Thanks.  5 port is overkill.  But that wont degrade speed correct.
    The satellite has ports right? So instead of the switch, I should be able to plug in the wyze base station into the orbi sattelite??
