jthespartan's avatar
Dec 22, 2018
Need guidance on what models are needed
I recenty moved to Virginia, and my house has ethernet cable running throughout it. I want to use an Orbi Router at the Verizon Fios point of entry in the basement. I also want to feed the ethernet c...
  • ekhalil's avatar
    Dec 22, 2018
    Your best option is to have another Satellite not a Router. If you want to have only one SSID throughout the house, then you need only to have one Router and couple of Satellites.
    So if you already have the RBR40 and RBW30 then you just need an additional RBS40 or RBS20. The RBS40 will give you more Ethernet ports than the RBS20.
    Good luck!
