AG11937
Mar 14, 2020Follower
Need help with Advanced Connection settings for RBR50: Verizon Wireless / Samsung S9 App Data Issue
Hi, I'm running the Orbi AC3000 System (RBR50 plus 2 satellites) in Router Mode and I need help and guidance making adjustments to some of the advanced networking settings to fix a connectivity issue...
Mar 14, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Enable Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- Retired_MemberMar 14, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).:smileysad:
