AG11937
Mar 14, 2020Follower
Need help with Advanced Connection settings for RBR50: Verizon Wireless / Samsung S9 App Data Issue
Hi, I'm running the Orbi AC3000 System (RBR50 plus 2 satellites) in Router Mode and I need help and guidance making adjustments to some of the advanced networking settings to fix a connectivity issue...
Mar 14, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Enable Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Retired_Member
Mar 14, 2020
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
:smileysad:
