Cooltwou
Apr 18, 2019Aspirant
Need help with NETGEAR Orbi
Also don’t see my model type here: Router Orbi: RBR40 Orbi Satellite: RBS40 I am having a problem here I got the router to connect to the app but the satellite has never turned blue at all it ha...
Cooltwou
Apr 21, 2019Aspirant
I have got the router to connect but not the Satellite & the Satellite always flashes white & the white never cuts off & I get green & orange & maybe red & I have done hard reset & eveything like that & nothing helps.
Also I tried to manual update the satellite but before you can do that it has to detect the satellite.
Apr 22, 2019Guru - Experienced User
Factory reset the RBS using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, Then press the black sync button on the Orbi router then press sync button on the RBS. Do this while having the RBS in same room as RBR.
30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected in final placement in home.
- CooltwouApr 22, 2019AspirantAlso I can’t tell firmware is for the satellite because it never detects the satellite at all & I don’t know any other way to find the firmware for the Satellite.
I have done that & nothing changed & it’s in the same room as the router & the Satellite never quit blinking white I thank the Satellite is defective because no matter how long you have the Satellite hooked up it never quits flashing white- FURRYe38Apr 22, 2019Guru - Experienced User
I would file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
One thing to try, connect up a wired PC to the back of the satellite. Power it off then back on, wait about 5 minutes. See if the PC get a 192.168.1.something address, if it does, try to log in to the RBS at 192.168.1.254 in a web browser. If not, then RBS needs to be replaced.
