mjcj421's avatar
mjcj421
Follower
Jun 24, 2020
need the network security code
where do i find the security network code
  • schumaku's avatar
    schumaku
    In a new install (or factory reset) Orbi device, the default network name and the network security key is printed on a banderole and below of your actual Orbi router device.
    • CrimpOn's avatar
      CrimpOn
      I think "autocorrect" got ahold of this.  My Orbi came with a clear plastic sleeve around  the top with the WiFi name (SSID) and password on it.  i.e. "banderole".   (My "used" Orbi I purchased off eBay did not.)  The information is also printed on the product label sticker on the bottom.
  • FURRYe38's avatar
    One can also use a wired PC and web browser to connect to the RBRs web page at 192.168.1.1.
