Stringztoo
May 02, 2021Tutor
Need to connect Harmony Hub to CBK752
I purchased a CBK752 system around a month ago because I wanted to bypass having to use a Spectrum modem. After setting it up I'm very happy with the Wi-Fi coverage but I cannot get my Harmony Hub to connect to the WiFi. I read that it's possibly being problematic because the Harmony Hub only connects on 2.4 GHz.
I found older solutions of people separating the 2.4 and 5 gigahertz bands by using Telnet, but it looks like firmware updates have disabled the ability to activate telnet and separate the two bands on newer Orbis.
I seriously need to find a way to set up a dedicated 2.4 gigahertz band for my Logitech Harmony Hub because I run a whole home theater using it and if I can't get the Harmony Hub setup properly I'm going to have huge issues. I did create a guest Wi-Fi but I'm reading now that it does not make a dedicated 2.4 GHz band and after trying it out, the Logitech Harmony Hub would not connect to my phone during setup while I was on the newly created Guest WiFi...
Separation of SSID names on Orbi systems is not supported. Telnet is not supported on Orbi AX systems.
(The Harmony Hub only connects on 2.4 GHz.) So does your unit connect to the system or not at all? 2.4Ghz and 5Ghz are on the same side of the network. It's up to devices to pick and choose where they connect too. Orbi just provides a platform is all.
Try disabling AX mode on 2.4Ghz and the basic tab/wireless settings check box.
Set CTS to 2347 Under Advanced Tab/Advanced Settings/Wireless Settings.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything.
FURRYe38 wrote:Separation of SSID names on Orbi systems is not supported. Telnet is not supported on Orbi AX systems.
"the Harmony Hub only connects on 2.4 GHz." So does your unit connect to the system or not at all? 2.4Ghz and 5Ghz are on the same side of the network. It's up to devices to pick and choose where they connect too. Orbi just provides a platform is all.
The Hub does not connect at all. Since I moved and went from a Verizon FiOS gigabit router to this Orbi router I had to reset the units. The Harmony Hubs connected to the FiOS router no problem. With this router they are not recognized. You have to setup each hub using your mobile phone while connected to your WiFi. Then once it's seen by your phone you can setup all the components. I read the Hub only works on 2.4Ghz bands, so naturally I need to setup these Hubs on a 2.4 band.
I will try your 2 suggestions when I get home from work.
Something to try as well, turn OFF the Orbi system. Use the FIOS wifi router and set set SSID name and PW as what your using on the Orbi. Get the device set up on the FIOS routers wifi. Once connected turn ON the Orbi system and let it come to ready. Power OFF the FIOS router. The device should auto migrate to the Orbi system.
I have the CBK752 system and have no issues with my Harmony hub. The system has been very reliable and none of my devices ever have trouble connecting.
