Magixians
May 10, 2025Tutor
Need to force phone to connect to 2.4GHz, how?
Hi I have the ORBI RB50 system. Today I installed a heat pump for my pool and the heat pump has a wifi interface and an app to connect to it, the app is called Inverboost. It says the phone...
Magixians
May 11, 2025Tutor
The Orbi is connected directly to a fiber converter, there's no modem or gateway.
