Magixians
May 10, 2025Tutor
Need to force phone to connect to 2.4GHz, how?
Hi I have the ORBI RB50 system. Today I installed a heat pump for my pool and the heat pump has a wifi interface and an app to connect to it, the app is called Inverboost. It says the phone...
Magixians
May 11, 2025Tutor
It's the fiber converter. It converts the fiber entering my house to ethernet, so I can connect the Orbi to internet. But I doubt it has anything to do with the issue at hand.
But please, if you think it is something else, please tell me what it is. Please also explain what it has to do with my issue, so I understand.
Thanks!
