Magixians
May 10, 2025Tutor
Need to force phone to connect to 2.4GHz, how?
Hi I have the ORBI RB50 system. Today I installed a heat pump for my pool and the heat pump has a wifi interface and an app to connect to it, the app is called Inverboost. It says the phone...
May 12, 2025Guru - Experienced User
What actual model is it? Double nats cause all kinds of issues. Without a model, its tough to rule out and its pointness to throw out random suggestions if we don't know what we're dealing with
