DirtyGoose
Jan 22, 2021Follower
need to return orbi model RBK20W.
i was connected to wifi but could not connect to mobile app or routerlogin.. after talking to netgear service associate found out due to our modem having a router also we could not connect to mobile app or routerlogin. will have to return orbi and do a factory reset before returning.
does the orbi router retain any personal infromation and is it safe to return.
thank you for your help
- vajimMaster
DirtyGoose wrote:i was connected to wifi but could not connect to mobile app or routerlogin.. after talking to netgear service associate found out due to our modem having a router also we could not connect to mobile app or routerlogin. will have to return orbi and do a factory reset before returning.
if your modem is actually a modem/router combo you may try this:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Hold it in for 15 seconds then let go.
- vajimMaster
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- vajimMaster
