jonandmarkuk
Sep 13, 2018Initiate
Nest Protect Battery
Is anyone else having issues with getting a Nest Protect battery to stay connected to the Orbi?
My Nest protect had been working fine for months with my previous Wifi setup (though never updated it's firmware for some reason). But since changing to the Orbi it will connect initially (even confirmed by Nest support) but fails to then check in afterwards.
I have tried everything I can think of and assigned it a static IP address, each time it will connect fine but then fail.
I'm really struggling and as it's 1 month out of warranty Nest are only willing to offer a discount on a replacement Protect unit.
Any help with getting Nest protect to stay connected would be appriciated.
- scorpionroAspirant
I have 4 Nest Protect(s) (all of them are the battery powered model) and I didn't notice any issues. They were actually triggered several times by (over)toasting some bread slices and they worked reliably each time.
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I would contact NEST support as well and ask for there help and information.
