GJ23
Feb 19, 2018Initiate
Netgear C7100V set up options with Orbi
I just upgraded my Internet speed with Xfinity to 300Mbps. I plan to replace my current modem (Arris AR TM822G) with Netgear C7100V. I have Orbi router RBR50 (firmware V2.1.2.18) with one RBS50 satel...
- Feb 19, 2018
Yes, those two option make sense. Neither option is better. It depends on what you want. If you are happy with Orbi as a router, then you can continue to use it that way. If the C7100V has some routing feature you need that isn't offered by Orbi, then you can run Orbi in AP mode.
st_shaw
Feb 19, 2018Master
- GJ23Feb 20, 2018Initiate
Thank you for replying. Appreciate it.
