Chuckg1
Aug 08, 2020Star
Netgear CM1200, Orbi RB50 router and Ooma Telo
I just replaced my Arris with the CM1200 and now my Ooma Telo won't connec t to the Internet through the Orbi router? Anyone got this setup working?
CrimpOn
Aug 08, 2020Guru - Experienced User
Can you please describe more about the configuration?
Previously, there was an Arris product (model number?).
The Orbi router was connected to the Arris.
And, the Ooma telephone device was connected to the Orbi.
Correct?
The Arris was replaced by the Netgear CM1200, so the Orbi is now connected to the CM1200, and the Ooma remains connected to the Orbi?
Correct?
- MstrbigAug 09, 2020Master
Since you changed routers, I assume you setup the Orbi to work with the router?
Have you rebooted or reconfigured the Ooma Telo? This may have to be done since the router has changed and the stored tables in the Ooma Telo may be looking for the Arris.
- Chuckg1Aug 09, 2020Star
I got to to work after a couple reboot and resets so yes OOMA works with the CM1200 ! Phones are up.
One very weird thing, I had set up "Services Block" in Security in the Orbi before and after plugging it to the CM1200, it started blocking all services to devices ignoring the schedule previously established, I had to delete all my security settings and recreate them.
Glad you got it to work. I'm finding on various Orbi models that sometimes a factory reset does not completely reset the router or satellites. It takes 2 or more factory resets to make sure the ghosts in the machine are erased.
