danall22
Aug 10, 2018Aspirant
Netgear DM200 and Orbi - Which one as router?
Hi all,
I have Vodafone broadband and the DM200 and Orbi - which one should run as the router - the DM200 or Orbi?
Many thanks,
Dan
danall22
Aug 12, 2018Aspirant
Does any one has advice on how to set this up to make it work?
Aug 13, 2018Guru - Experienced User
I would review the user manual for set up instructions.
Connect a wired PC to the Orbi router and walk thru the setup wizard. This will help you get the Orbi setup.
Also:
https://community.netgear.com/t5/Orbi/draytek-vigor-130-and-Orbi-Bridge-or-AP/m-p/1621623#M39019
