ATbarker's avatar
ATbarker
Follower
Aug 07, 2022
Netgear extensionfor RBR40
Have Router RBR40 and satellite RBW30 on the first floor, because the house is naroow and long.  What can I add to strengten the signal in the basement?
  • You can add another satellites.
    Compatible models are:
    RBS20
    RBW30
    RBS40
    RBS40V
    RBS50
    RBS50Y
    Keep in mind, the 50 series have a wider backhaul but will connect at the lower 866mbps backhaul the 40 series use.
  • michaelkenward's avatar
    michaelkenward
    More satellites that work with the RBR40?
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Orbi - NETGEAR Communities
  • plemans's avatar
    RBS20
    RBW30
    RBS40
    RBS40V
    RBS50
    RBS50Y
