zN
Nov 13, 2017Aspirant
Netgear Nighthawk R7000 and Netgear Orbi
Hi - Just got the new Orbi and I love it. Before I got this router, I had the Nighthawk R7000 and am wondering if there's a way to make the Orbi Base, Orbi Satellite and Nighthawk all work together? ...
- Nov 17, 2017
zN wrote:Roger - apologies for the repeat. Is this the configuration you have?
Cable Modem--->cable to--->Nighthawk R7000 (WiFi off)--->cable to--->Orbi Base (AP mode)--->Orbi Satellite (AP mode?)
This means you only have one SSID - the one from the Orbi Base in the house, right?
Thank you.
Yes, sorry, I wasn't sure who you were asking. Yes, this is what I've been doing for some time now, only one SSID. And it works really well!
In addition, for the Orbi I have it at lowest txpower (25%, as I recall) on 2.4GHz., since all my clients support 5GHz. So I don't want the Orbi to use 2.4GHz. And none of my clients are connected via the 2.4GHz. network by the Orbi, so everything's configured the way that I want it.
cyberprashant
Nov 13, 2017Luminary
This is exactly the setup I have. IT will work fine. Set the orbi into access point mode. Connect Orbi WAN port to R7000 LAN port (and anything else you want to directly wire to the LAN there). R7000 WAN to cable. I would use a different SSID for the r7000 and the orbi (o/w no point in orbi mesh system as collisions will occur causing unreliability).
